Congratulations Tor!! Looks like a successful launch and a great build.
I really like the detail on the ends. Nice work.
Which lake is that?
Amazing how the cooler weather slows down the build somewhat. I'm trailing behind you a little.....but not too far off a launch myself.
DK - First build
It should be well cured. I hadn't put fresh epoxy on that part for weeks and I finished it whilst the the temperature was in the high twenties (that's about 80 in the big numbers).
It's only seen the outside light for 2 hours and the sun ain't shining at the moment (please don't mention the ozone hole
) Hopefully it will clear up when it's thoroughly dry.
I was so pleased with that result). Gonna try Aura Vale in a couple of weeks and Lysterfeild when my mate finishes his sailing dingy in 3 weeks.
Shall wait until spring before I try it on the Yarra upstream of Warrandyte...
It was Lilydale Lake, good for a practice paddle and a playground for the kids (although they lost interest in the playground as soon as we launched the boatolsnappa wrote:Which lake is that?
Teddy Madison
Not being anywhere near expert, here's my 2 cents:
1. Could it be Amine blush? You state that it has not been varnished yet (This is assuming you didn't use a "blush resistant" hardener).
2. I see you used a charcoal heater to keep the epoxy warm at some point which would have surrounded the area in carbon. A boat builder friend of mine warned me against using Propane or any thing else that is high carbon because it can cause fogging of the epoxy.
3. If you used West System 206, they told me that it can fog for no apparent reason and that is why they developed 207.
Wayne
Wayne
Wayne
Free Laker - In Progress!!!
G'day Tor,
Good job mate. Really nice boat, congratulations.
Re the clouding, What resin did you use? It looks a lot like ammine blush to me.
Try scrubbing with warm soapy water.
Hey Mick, I used "botecote", haven't tried to remove it yet, I want to see if it goes away when dry. I'll have a crack at it at the weekend and we're planning to take it out again in 2 weeks so I'll see if it come back. Assuming it goes away...Re the clouding, What resin did you use? It looks a lot like ammine blush to me
Plans for little foot arrived today,
