This is my Laker when first completed.
After a year or so of use, she is looking a little worse for the wear
She doesn't look too bad until you take a closer look
The first spot is from saltwater intrusion through some gaps in the epoxy.
The second and third shots are where the bulkhead behind the seat is. It is a sealed bulkhead. I can only assume that moisture seeped in and caused the mildew. Because there is no ventilation, the moisture could not get out. Since I stored my Laker on the top of my truck for most of it's life, the Florida sun took quite tole on the epoxy.
