Is this a completely idiotic idea?
Most bead and cove strips are 1/4” thick or about 6mm. Could I glue up a flat panel of them and then cut out the stitch and glue panels from it?
Re: Is this a completely idiotic idea?
I was thinking especially for decks it would be easier to glue up a flat panel cut it to size and glue it down and it would look like a strip planked deck
It's been by members of this forum. If you're doing that, I suggest making cheap full length patterns and alternate strips for full length of spliced panel. In other words, don't make strip panels and then butt splice them together. Make as one long panel.
That was my thought get 17’ strips and make a long panel from them wide enough to cut the panel from so no joins but not individual strips either
oldbuffpilot
- Type of boat I like: pirogue for fishing
Check out strip,stitch, and glue. Several examples in Builders log forum.
viewtopic.php?f=8&t=4035
"To Them We Owe a Solemn Obligation"
It looks like they fiberglassed the panels before stitching together?
